panelview1000
osamamalhy
Jan 2006
alex
89
good day every one
i like to know the required cables
to do programming for panelview1000(711-K10G16 PV1000 Gray Key)
also the cable need to connect it to the plc (slc5/04)
also can i do these cables by my self?
regards
osamamalhy said:
good day every one
regards
Straight thru cable to program it and the same cable to connect it to your SLC5/04's serial port.
panelview 1000
good day
Mickey
i think that the destance well be more than the 15.0m
for this panel what other communincation methods i could use , if any cabels required kindly advice
osamamalhy said:
good day
Mickey
How far over the stated 15m are you?
I have run RS232 cable to 150ft ( 45m) without problems. Use good shielded cable in conduit. ( pushing the limits,I know)
RS232 extenders, line drivers, short haul modems will work also.
Black Box would be one source for these. (see link)
http://www.blackbox.com/Catalog/Category.aspx?cid=381,1452,1465
Another option (costly) would be to change your PV to one that supports DH485 (4000ft) or DH+(10000ft)
Mickey
Good day
it working very well ,many thanks
to connect aprinter to the printer serial port ,what should i do ?
i do activate to port for printing
how to configure the printer?do i need spicila one
kindly advice
osamamalhy said:
Mickey
Good day
kindly advice
Glad to hear its working.
I have never used the print option so I'm not going to be much help on that . I'm sure someone who has will jump in to give you some help with that.
Hi Guy, some times i receive this message in my PV1000: 637 Communication Driver has FAULTED -contact technical support. after there is no...
3,900
Hello everyone, I am back once again with a very simple question, more like need a second opinion than anything else. Am i correct to assume that...
1,190
Good Morning All, I am new to Rockwell Automation products.Hope some one can advise me to purchase a right HMI software product. I was asked to...
4,078
Hello once again.... I am a Wiz with RSView32 and EZ automation. So along comes the salesman ..... Factory Talk Me 8.00 Bar Graph / Gauges, Has...
2,388
Hi all, Short question, hopefully it has a simple answer: I got a bunch of alarms in my panel. Alarms pop up fine, but they show 1-by-1. And...
2,838
