logixjock
Hi, I am using some numeric entry objects to modify some tag values in my CLX recipe UDT. I would like to use an expression to enable/disable writing to the UDT tag based on the condition of an enable tag. Looking through the user manual I come up with
IF
(EnableTag)==1
ELSE
{#103}
Where 103 is the parameter file value representing the tag being written to. Will this work? The examples in the UM only show something like
? * 1000
for the else case. Basically if the enable tag is false, I want the numeric input to write the value of the recipe tag back over itself instead of writing the value input by the operator.
I suppose I should probably just call tech support in the morning, or test it out on the cell, but it's been bugging me all night. Did some googling around, but as you all know, it always leads here or the other site.
I'll post back later if I find an answer myself.
IF
(EnableTag)==1
ELSE
{#103}
? * 1000
