Parking Garage Ladder Diagram
ahillukka
Jul 2016
TRF
I am supposed to create a ladder diagram for a parking garage indicating a green light when there is parking space. Include counters so it can hold up to 25 cars. When there are 23 to 24 cars, the yellow light will come on. When it is full a red light comes on. Also, a red light will come on when it rains out. Every day it will reset.
I am not sure where to start.
Any help would be great.
What class is it for? Do you need to select sensors?
Its pretty easy. Have an entrance and exit. Add cars going through the entrance and subtrac cars going through the exit.
24 hour timer will -(RES)- counter.
Easy A
If you aren't sure how to solve the problem, start with a smaller one.
- Under what condition do you increment cars? What happens if you count above your limit?
- Start by unconditionally energizing the lights. What does it take to condition the same outputs?
It is for ECT 295. No, I don't need to select sensors. Just a moisture sensor for when it rains. The cars will be counted by ones. It is just a basic parking garage, we didn't go in depth so going above the limit isn't an option. I just need a basic LogixPro ladder diagram for a parking garage.
Excellent advice. I remember getting stumped by programming problems that I had no clue where to start. And by the end of the lab, I couldnt understand why I trouble figuring it out.
You'll probably need these instructions CTU, TON, GTR, MOV, SUB, RES and ADD maybe a few other.
You'll figure it out.
Here is the actual assignment:
The process consists of a parking garage with an entrance and an exit door. The garage has 25 parking spaces. We assume the garage is empty at the beginning of the day. The parking garage manager starts the operation by pressing an NO pushbutton. As soon as the process starts, a green light turns on at the entrance of the garage indicating that parking space is available. The number of parking vehicles in the garage is constantly monitored as vehicles enter or exit the garage. To indicate that a vehicle has entered the garage, an NO pushbutton is pressed. Another NO pushbutton is pressed if a vehicle leaves the garage. If the number of parked vehicles in the garage is 23 or 24, the green light is turned off and a yellow light flashes continuously at the rate of one second on and one second off, indicating that the garage is getting almost full. If the garage is full, the flashing yellow light turns off and a red light turns on indicating that the garage is FULL. At this point if one or two vehicles leave the garage, the red light turns off and the flashing yellow light turns on. If additional vehicles leave the garage, the flashing yellow light turns off and the green light is turned back on.
For safety issues, the manager of the parking garage has decided not to allow any vehicle entering the parking garage if it is raining. When it rains, the red light should turn on at the entrance indicating the garage is full (even though it may not be full). The red light should be on for the duration of rain even if all cars leave the garage. When rain stops, normal operation resumes. Construct and incorporate a moisture sensor to simulate rain when the sensor is sprayed with salt water. At the end of the day, a NC pushbutton is pressed to stop the process and reset all counters.
Sorry Timer2 should also have a preset of 1000. And the stop PB should break the seal circuit and turn 'System_On' off, or am I missing something?
Yes: you're missing the fact that there's a difference in a real world NC contact and the XIC/XIO instructions used in a PLC program. Your system will only be able to function while you keep pressing the NC stop pushbutton.
Hi all iam new to ladder logic slowing trying to learn more things about plc and ladder logics i need help in constructing parking garage...
16,149
I have an assignment that I have to do with a PLC and a parking garage. The parking garage can fit 15 cars but the light has to be green up until...
2,338
A new approach to this problem. :hmmm: Credits: https://xkcd.com/1651/
1,601
Hello Everyone, I am working on a program to run on a Direct Logic D0-05 DR-D PLC for a parking garage program. I have a program I wrote...
73
24,535
Hi All! I am new to the territory and I am seeking assistance with a Prologix500 Ladder design for a 50 plus vehicle parking garage with sensors...
1,817
