Partner Redundancy Controller goes into minor fault while trying to Synchronize.
Spotless
Sep 2022
Port Harcourt
Dear Team,
I need experts advice on how to resolve the problem below :
We have two 1756-L55 RSLogix5000 Controllers installed in a redundancy configuration each with one 1756-ENBT Module.
Problem :
Everything looks good until attempt to synchronize, then the controller goes into minor fault with solid red and the fault log below.
(Type 04) Program Fault
(Code 07) GSV/SSV destination tag too small to hold all data.
I have checked configuration of all the GSV instructions and every looks good.
The primary controller can work without coming up with this fault.
The same fault was reported even when the active controller was made the secondary. This suggests the problem is not controller specific but synchronization problem.
Welcome to the PLCTalk forum community !
ControlLogix Redundancy systems require a very specific set of firmware in the CPU and modules, and the use of the correct Redundancy Tool to synchronize them and read information from the redundancy modules. You absolutely need to read and understand the ControlLogix Redundancy release notes for your specific system as it was built.
The error you're seeing is probably a real Minor Fault error. GSV instructions can read data of many different sizes and formats from the controller's internal objects; some are ordinary single DINT tags, others are arrays of SINT or INT or DINT tags.
Take a very close look at the GSV and post the details. If it's a Redundancy Object related GSV, it might be that the GSV isn't the source of the synch failure, but rather that it's reading the actual source of the synch failure.
Hello, I have a running ControlLogix Enhanced redundancy system: The first chassis has in Slot 0 the Controller, in Slot 1 the Redundancy...
1,685
I am trying to figure out if I can use a old L73S I have laying around for a test PLC for my current project. I dont have the safety partner but...
1,561
Hi all, I have an issue with S7-1512C cpu. Cpu has error Error on partner - Wrong partner port. Project has 1cpu, 1hmi and some tcp connection...
5,666
1756-L6xS and 1756-L7xS can not operate without a Safety Partner and is SIL3 level. However, 1756-L8xS can operate without a Safety Partner and...
4,052
Hello I am trying to "Monitor" the execution of my PLC program, i dont have MPI or hardware at all, i just try to do this using the simulator...
4,144
