Parts per Minute Display
jthornton
Jul 2002
Poplar Bluff, MO
295
I have one customer that i programmed a parts per minute display. I used without much thought on my part the "number of parts per time period" method. Count the number of parts in 10 seconds multiply by 6 and there you go. Not! the machine if it has one more or one less the display jumps by enough to concern the customer. Ok If I use a longer time period that will smooth it out but the delay in speed changes will be slow.... If I use time per number of parts I feel that I will be in the same boat... Is there a slick way to do a running average that will not jump around alot?
TIA
John
I use a timer with a time base of .01 sec and then divide this into 6000. This gives me a realtime parts/min.
Example:
If T4:0.acc = 200
6000/200 = 30 parts/min.
Averaging
Maybe if you store the parts per minute every 5 seconds or so in a 20 integer fifo and then average... or any variation on this theme to give the customer the desired responsiveness/smoothness.
Sorry about that.
The timer is tracking the time between parts.
Back to my example:
200 time units/part
100 time units = 1 sec.
(200 time units/parts)/(100 time units/1 sec) = 2 sec/part
60 sec. = 1 min.
Now
(60 sec/1 min.)/(2 sec./part) = 30 parts/min
Instead of doing two computations I multiplied my
(60 sec.*100 time units) = 6000 since these are both constants
Hope this helps
Here is what I am working with and what I need to do. I have a machine that runs at a top speed of 60 parts per minute. What I need to do is...
49
31,879
Hi All, Could anyone give me some pointers of how to calculate the parts per min, on a simple semi auto machine, using S7 300 PLC and a...
6,606
Does anyone have any logic for Allen Bradley for parts per minute, and rolling averages. Im trying to write logic for uptime / downtime /...
5,338
What is the easiest way of programming a omron plc to calculate parts per hour :D .The value will be displayed on seven segment displays
5,268
82
