Password protected plc in run mode
Mar 2023
Baton Rouge
I have an Allen Bradley, Micro 820, 2080-LC20-20QBB that is password protected and is set in run mode. The plc was sent to me with a password that I do not know. This means that I can not use the connected components workbench to program the plc.
To get around this, I have a MicroSD card with a ConfigMeFirst.txt file on the root of the MicroSD card with the following text:
[PM]
[FWFILE = firmware\2080-LC20-20QBB_10_012_bld_01.nvs]
[FWDOWN = 1]
[END]
Then I put the microSD into the plc, power cycle it, wait for the SD light on the PLC to turn off after about 5ish seconds, and then proceed to connect to CCW with my ethernet.
The PLC acts like it read the microSD but it does not change anything about the PLC and I needed some suggestions on how to fix it.
Thanks!
(I have also tried just [PM] [END] and then connecting to firmware downgrade but it will not work)
PLC firmware: 12.011
MicroSD: SDHC with FAT32 File system
Hi guys Simple question. Is there any possible way around Siemens plc code that has PLC Access Rights enabled? I have a plc 315-2DP which I...
18
10,798
Hello I have a FPO panasonic plc in a chineses built machine that doesnt function the way its suppose to. When I try and get online it asks for a...
9,777
Hi Friends, I want to download Password Protected Software from one PLC Simatic S7-200 CPU 224 to other PLC of same configuration. Is there anyone...
4,044
Pls anyone help me out to crack the Codesys lib File pls share password for the if any application to crack or any master key for Codesys library...
779
How difficult is it to update a program in the field on a password protected Micro820 PLC using a SD card?
18
14,266
