Does anyone know if it is possible to pause a single step in Logix SFC?
I've searched for pausing in the manual and all I could find was the instruction to pause the entire SFC, and that instruction has to be called from a separate ladder or ST routine.
What I'm looking to do is pause a single step within my SFC without having to have logic in an external routine. My application is I have a mixing timer and I want to make the step timer conditional on the mixing pump running. I check for the pump running before going to the step, but while it's in the step, I want to be able to prevent the step timer from incrementing if the pump interlocks or goes off for any reason.
I'm a bit new to SFC's in Logix, but from what I see so far, the only timers accessible within the SFC are the Step timers themselves, and I can't see a good way to make the Step timer stop based on a condition.
I was thinking of trying to have some logic in the Action that would write to the Step.T value to keep the timer accumulator fixed at a certain value, but I couldn't see a way to do this...I'm running the SFC in a continuous task so I can't just subtract a set value.
My goal is to keep all the logic contained in the SFC. I know how to solve this issue by putting a TON in a ladder instruction and referencing that in the SFC transition, but I was hoping someone might have a more elegant solution that keeps all the logic contained within the SFC.
Any suggestions are appreciated.
-Greg
-Greg
