PB32 on windows 7 using xp mode
Mporter4
Sep 2011
georgia
39
I have windows 7 with a "professional" added on.I plan on using this in XP mode. Is there anything I need to do other that install my software... Like upgrade Rslinx?
My old desk top crashed and I lost everything. So I will have to upgrade my rs logic 500 to the newest version to run it on windows 7 because all I have is the floppy master key and it's stuck in my old pc.... Now I will just use pb.32 in xp mode on the new laptop as AB does not offer Pb32 for windows 7.
So any help would be appreciated.
IIRC PB32 will run alright on Win7 32-bit, but not 64-bit. I have to use XP mode to use it.
RSLinx 2.57 is what I have installed in my XP-Mode Machine.
What driver are you using?
If RS232 (DF1), check to see if the VM com port is pointing to your serial port.
The PIC/AIC driver will not work in a virtual machine.
:D OK. Won't ask about the shift...
What version of Windows 7? 64-bit? 32-bit? I assume 32-bit, since-- as I've stated-- PB32 won't work on 64-bit.
What version of RSLinx?
Is this the same USB adapter you used before? IIRC, Keyspan uses a Prolific chipset in it. Perhaps using something with an FTDI chipset in it would work better for you.
Like I said on my first post I am planning on using the XP mode but I have not yet. So there is not anything special I need to do as far as updatting rslinx or anything.
thanks.
I had this pop up today on a PanelBuilder, PanelView 550. I can not find it in the PB messages any where. I pressed any key like it said. Every...
2,633
On PB32, PV 600 I want to add a screen for a analog tempurature trend. How does the Graphic Indicators-linear set up work? Where do I add the tag...
1,191
Hello, I am hoping for some help with setting up a .mer. I will try and give as much detail as possible, thanks. I am trying to convert a .pba...
2,279
hi guys im having an issues converting a panelview 600 to panelview plus 600 ? I have done 2 hmi program conversion on factorytalk studio but...
1,578
Hi Friends ! I'm having a little challenge here, I'm almost done in my conversion project from panelBuilder to Factory Talk. I really need a...
1,580
