PBase Software
randy
Supporting Member
Apr 2002
158
We have an A-B Basic module for communication for a scanner and printer. I have the PBASE software and I was able to upload the program. I need to modify the print size for the Zebra printer we have for the bar code. After downloading the program changes we are no longer able to print the label. I tried to download the program several times and still no luck with the printer. I can also upload the program with no problem.
Is there something that I have to do in order to set this Basic module in run mode that I am over looking?
rmonroe
Please get all the manuals relating to this module from AB. There is one on the module itself and one on the BASIC programming. Actually you can do all iteractions with the BASIC module using Hyperterminal but that's another thread.
In addition to downloading the program the module must be placed in the run mode. Also look up the methods of storing the program to its permanent memory and setting it up to automatically run at power up. None of these actions are performed by default.
In manual 1746-rm001_.en pay special attention to the PROG and PROG2 commands.
Pbase
When I download the program file through the terminal on the PBASE software the program toward the end seems like it get's mix's up. I do a "PROG" and I get a "Programming Sequence Failure".
I have the BAUD RATE set at 1200...
rmonroe
I have a Basic Module and tried to program it with PBASE software and what i did change DipSwitch 4 anf Connected to port one and when i do...
1,894
Is anyone here familiar with AB's 1746-BAS basic module? 9 out of 10 downloads result in corrupted data (short 232 lead; office environment). As...
4,885
Hello, I want to program and testing a basic program for the Allen Bradley Basic module 1771-db series b. Is there anyone who has the Basic...
7,890
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
48
146
