PC control
Angelo281
Feb 2003
i desparate need source code in Vb or C,C++ (prefferablly in VB)to control LPT or Serial port, in order to count revolutions,0V - +5V and start a counter.It is very important for me.
It's unlikely you're going to be able to use VB to count pulses on an I/O pin of a PC port with any decent speed. If I had such a challenge I'd spend a couple of bucks on a hardware device that communicated with a simple protocol to a COM port.
This might be of interest to you:
http://www.weedtech.com/wtpct-m.html
If I were you I would program an 8051 or any relative microcontroler pic type for example and communicate with pc using vb and mscomm activix there is a good routine named as com event which can realy help in data recieving (sending is much more easier ) this way would be rather inexpensive.
If you are not informed about microcontrollers you can use a usart instead as a serial to parrallel device.
using the LPT port with VB ?
I think you must use VC with that
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
145
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
67
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
72
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
153
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
149
