PC Malfunction alarm
jos6s238
Nov 2016
Tustin,CA
Hi friends I'm new in the forum and I heave an small problem with a Toshiba Die Casting machine. It has a Toscast system and initially had the PC "Malfunction alarm" I replaced the 3 power supply one for main processor, one for I/O and the other for PC(were VGA, analog I/O, and Keypad) nothing happens! I test all I/O's cards replacing them one by one by new spare cards, the alarm still there. I test the processor in another machine and there was no alarm in the other machine. I test the processor of the other machine in the alarmed unit and the alarm shows again.
the last test I did was installing an spare mother board with all boards on it!
The alarm disappears but I don't heave reading of inputs on VGA screen, and the hydraulic pump wont turn on. But I heave I/O's in the PLC.
Hello I have 1214C DC/DC/DC CPU which I can't communicate with it through pc. When I'm Trying to search the cpu in tia portal I can't find it...
1,473
Good Morning , We have a new Fortress Stealth Metal Detector. About 30' away we have a machine with motors and solenoids on it , Whenever...
2,199
hey guys, i made a application for a PV plus 1000 ver 8 that uses two shortcuts. everything works perfectly on the design side using the play...
2,322
Hi Everyone, Yesterday we encountered an issue where I had a 480V 3Ph 2HP Powerflex 525 blow up. Upon further inspection, we noticed that 10...
21
5,991
I have a problem with the communication processor 6GK1543-1AA01 linking S5 135U (CPU 928) to an OP30 display. The Stop and Run leds are both ON...
3,595
