PC-XP Control program?
Dec 2008
Boston
I have a question on PC control application. Here is what is happening so far I have 10-DL05 PLC’s controlling a GS2 frequency motor drive. The input from the motor is with a M.D. Quad encoder 120ppr and an AK1 proximity switch for reset. All ten PLC’s do the same function and have user input via a C-More micro-Graphic GUI touch screen. They all work fine in the stand alone mode operator mode. So each box includes 1-DL05, 1-encoder, 1 proximity switch, 1-GS2 motor control in 10 different locations.
The PLC’s are currently programmed using Direct Soft 5 using the typical ladder programming style.
OK! Here is what I want to do! I want to connect all ten PLC’c to a PC via 100/base-T to a computer running MS-XP operating system. From the PC I want to be able to control all or any one PLC’s functions using a Graphical Programming program running on the remote computer. This needs to be something easy that the average person can do by point and click methodology.
So other than custom software is there any application that can achieve the desire result?
Mike -
Plant PLC has no reasonable stop start sequencer. There is 3 states, Available, Start & Stop. A 10 sec timer exists in the Stop Ladder that is...
2,713
Hello everyone! I have an old QuickPanel Control that I need to either modify or upgrade. and I need to get the program out of it if possible. So...
5,515
I haven't done any programming for a HC900 Control Station before. I was wondering if there was a way to generate a popup display from a bit in...
1,426
Hi , I Need to write a Logic for Diameter Calculation using estimated method and control of speed for Winder application . Please share if you...
2,756
We use GE Logicmaster 90 (V9.05) DOS software on a Windows XP laptop to maintain one instance of PLC equipment using a GE Series 9030 CPU and I/O...
5,421
