PCCC Messaging. RFID ethernet.
yasirkhi
Oct 2011
Toronto
136
Hi There,
I have been trying to communicate IC-KP2-2HB17-2V1D (pepperl and fuchs)and Slc5/05 via msg instruction. But not luck yet.
Has anybody tried it. Or I have to use Rslogix5000 for that project. Any help would be much appreciated.
What OS and Firmware revision is your SLC-5/05 ? Very old controllers that don't support "multi-hop" messaging won't support PCCC over EtherNet/IP.
Make sure that you are using the "Multi-Hop" option on the Message instruction. Configure it as though the message was going to a ControlLogix in Slot 0.
What is the exact error code you are getting ? Can you describe in detail the settings you used for the MSG instruction ?
SLC-5/05 controllers with firmware from the past few years (I think FRN10 and 11) have the Ethernet Explicit Message (EEM) as well, which might help you read EtherNet/IP Assembly objects.
Ken,
Please check the attached program just to test the data receiving from RFID.
Please check the pdf file from this link. http://www.pepperl-fuchs.us/usa/en/classid_2474.htm?view=productdetails&prodid=40511
It says in pdf to use pccc messaging when communicating PLC5 or SLC5/05.
Am I doing something wrong that I don't read anything from the tag. I set the tag on continuous scan mode.
If you watch this link for compactlogix http://www.youtube.com/watch?v=dxt1khYCaxY&feature=share&list=UUImjaJysobznc5A1Ce0hM2A may help , how to work with SLC5.
thanks.
Hi guys, The last time I posted something, I got severely told off for not giving a full background as to what I wanted to know and what I was...
2,301
Hello Guys, I am a Graduate Student, I am working on project with deals with PCCC object. Anyone there who can help me out finding a manual or...
2,200
Hi! I'm trying to understand the structure of the "Protected Typed Logical Read with Three Address Fields" function, and I am using the online...
1,643
Hi I am working with a SLC 5/05 connected to an Ethernet switch that is connected to a Fieldserver (From LonWorks). (All CAT 5 connections) The...
6,062
Hi All, I want to know PowerFlex tag stucture. I have question regarding this. 1) Like in Control Logix we can define/Create Tags. Can we...
4,463
