Sorrells97,
I can only offer you information regarding what we offer.
The PDA interface software we offer is strictly an interface. It isn't used for datalogging. You have the ability to read and write registers, obtain status of coils. You can set up what are called "aliases" with in the interface. An alias is a programmed function that can be labelled. An example would be "check pump status" When you select this alias, it would be programmed to check the status of the pump within the PLC. You have a level of password protection whereby you can make aliases read only, or read / write.
Basically the software creates a handheld operator interface for your PDA. Our software uses the Palm O/S and communicates to the PLC via ModBus RTU.
For your application, the front end would still be used. What the PDA would allow you to do is make modifications at your location, rather than go back to the control room. It would allow you to have one interface that can be plugged into various machines. It would allow your maintenance people to troubleshoot your product / equipment without using a laptop (should they only have to check internal information.
I do know that there are companies out there that offer other versions with different capabilities for more money.
An other company that I am aware of that offers some sort of PDA interface is Software Horizons -
www.shorizons.com I do know there are others, but there names escape me at this point.
Hope this helps you out.
God Bless,
