Pepperl+Fuchs switch Asi programming?
PiperJohn
Mar 2022
Michigan
61
Hi folks,
I had trouble with door switches on a machine I was working on today.
What first appeared to be as a simple reed switch turned out to be a Pepperl+Fuchs AS-i connected switch VAA-2E-IER2-S-0,15M-V1
I swapped the bad switch with another door nearby but the description on the HMI screen changed names.
This tells me the switch iitself is addressed.
If I order another switch (part 229232) How would I program it?
It's been a few years but they are programmable you need an ASI programmer they are availlable from P&F I believe, however, if it is set to address 0 then I know some ASI controllers will re-program them providing there is only one that was at fault & that one was replaced by a new one addressed to 0.
I have not worked with P&F ASI but IFM & Mitsubishi ASI cards, on those there are two buttons on the card we mainly used the programmer to set the address however, I did do a couple by pressing the program button on the ASI card let it scan through & it re-programmed the new sensor, not sure if others have this capability. It is a good idea to have a list of the ASI sensors with their addresses as a silly mistake can put it in a right mess.
I know one engineer replaced 2 at the same time not knowing the sensors were default at 0 it wrote the wrong addresses as far as I could gather although it was not known if the sensors were already programed by somebody i.e. as a test or if they had been replaced, not made a difference etc.
Make sure you have the right connector or actual socket on the programmer we had a load of asi valve heads these needed a cable with a 4 pin 12mm round plug to open ends (2 wires) as the programmer had a socket to fit a proximity directly but the valve heads only had a connector block we also had some oddball ones that used a small 5mm plug.
Normally as long as you program the sensor to the right address and not re-scanned the ASI card then just plug it in & it will work.
One of our systems had over 800 of these mostly valves so we had a chart on the wall with all the valve numbers & addresses on it.
The programmer should have it. Even if I have the wrong connector, I think I can just splice another cable end provided polarity is observed.
Hopefully I won't screw something up. LOL
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
337
Hello everyone Iam working on washing machine which washing onion and water level is very critical for the process. The machine used IFM 121 for...
149
493
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
235
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
122
