PEPS Antenna Test
timryder
Feb 2007
Macomb MI
176
I have an application where I need to test for the presence of a PEPS antenna in the center console of a car. I need to automate this test where I have an operator hook up a harness to the console and the PLC can initiate a test to verify this antenna is there.
I know that the 2 connections of the antenna do not touch, so resistance is not an option. I'm not really sure where to go with this one... anyone have any ideas how to test an antenna? The MFG doesn't provide me with a solution I can automate.
Capacitance meter with analog output to feed into your PLC
GLK Instruments
http://www.glkinst.com/
Model 3000 Standard Features -
  • [FONT=Arial, Helvetica, sans-serif]Convenient 2-Terminal Capacitance Measurements using Low Cost Shielded Probes[/FONT]
  • [FONT=Arial,Helvetica]ONE Femtofarad (1x10-15 Farad) Resolution & Basic Accuracy of 0.1%![/FONT]
  • [FONT=Arial, Helvetica, sans-serif]The Model 3000 Capacitance Meter includes both analog output and digital I/O at the USB Port[/FONT]
  • [FONT=Arial,Helvetica]Ideal for High Accuracy Measurement of Chip Capacitors[/FONT]
  • [FONT=Arial,Helvetica]Very Low Power Consumption on Battery Power (< 3mA at 9 V) [/FONT]
  • [FONT=Arial, Helvetica, sans-serif]LabVIEW© Support [/FONT][FONT=Arial, Helvetica, sans-serif]View LabVIEW© Screen shot[/FONT]
  • [FONT=Arial,Helvetica]Extended Range and Higher Resolution Available Through USB Port[/FONT]
Please tell how data is transferring from GPS smart anttenna with PLC(Allen bradley1769 Compactlogix L32E controller) and I/O's Mapping...
1,830
Hello everybody, do you know if an external antenna is necessary for the GSM module ILX800-SMSG ? Or does it have an internal antenna? Thank you...
2,158
Has anyone ever used an RF antenna made by RF ID to communicate to a Allen Bradley Compactlogix controller, and if so could you point me in the...
1,442
Good day experts! I'm working on a Profinet system which passes through unmanaged switches and a 50 Mbps antennas (please see attached file for...
3,104
Hi I have problem with my siemens s7-1200 plcs after lightning, they are all messed up and i have to reload them. I have tried to use surge...
1,482
