Outside 3g/gprs antenna
m2ti
Oct 2010
C
Hi
I have problem with my siemens s7-1200 plcs after lightning, they are all messed up and i have to reload them. I have tried to use surge arrestor with my antennas but they are too slow for that kind of lightning impulse.
Are there other antennas or solution to use?
Thanks in advance !
There are old lightening protection methods. One of the most effective ways is to install an overhead wire grid (a shield) that has large grounding conductors at each support post. The problem would be that if you have antennas, the lightening protection grid will also block signals to the antennas.
A less-effective method is to install 4 lightening rods on posts in a square and slightly above the antennas. These will not intercept all strikes but maybe 80% of the strikes, and will not block all of your signals.
I was looking at a Studio5000 PLC file as reference, and noticed the "standard" for this job used was using program tags for each program folder...
1,563
Hi, I'm an absolute beginner in PLCs.. I have an Allen Bradley SLC5/03 PLC installed on a machine, the program is working well, I uploaded it to...
25
3,860
Is there a difference of behavior between the PLC5 and the Logix series when it comes to JSR behavior? Assuming I do nothing to this bit...
19
2,856
Hello! I am working with a project that uses lots of Parameter files to pass information between screens. When I open the parameter file in...
1,892
According to UL, NEC, OSHA, etc. Do machine primary disconnects have to be switchable from outside the panel? Or can I have a din rail mount...
1,660
