Photoelectric & noise
theripley
Jul 2008
laguna
545
Can noise (electrical noise) affects a photoelectric sensor?
We have encountered a case wherein the signal "chatters", but when wire was replaced with a shielded wire (with wire shield properly grounded), the signal does not "chatter" anymore.
Can someone help me figure this out?
The most common cause of sensor noise I've run into is when the sensor wire is run in close proximity to a noisy source (inverter, high voltage, etc..)
Inverters are especially noisy. Many times the motor cabling isn't shielded.
Definitely.
I once had to replace all of the 2-wire inductive proximity sensors on a machine with 3-wire sensors because the 2-wire would "chatter" when the nearby VFDs turned on.
I see. The sensor wire is in proximity to the motor wires from VFD, I now know. Thank you.
Aside from using shielded wire, is there any other option? Shielded wires are quiet expensive.
either use electrical isolation by distance.
or a 'Faraday Cage' / steel conduit.
(this is the effect of shielding)
what you are looking at is an induced voltage.
Hey, I am entirely new to PLC's and am trying to help my friend with a project. He wants to take the signal from a PNP photoelectric sensor as...
2,241
In short, I have inherited a project that has been abandoned by the original installers. Yes abandoned before it has been finished. They realized...
29
10,386
Hey everyone, We are trying to attach a photoelectric sensor to a conveyor to count the number of parts produced in a plant. However, there is no...
2,185
I am using a few Efector OJ 5036 Laser Sensors. I was using reflective tape but does not seem consistent enough. Does anyone know of any long...
1,662
Hello, I have a couple of questions and would appreciate any help from you guys. Im basically trying to learn PLC's by playing with them at home...
5,547
