PIB, PID, PQB, PQW and indirect adressing
userxyz
May 2002
any
2,768
I have a function with in/out parameters.
The connected parameters for motor 1 are:
PIB304
PID308
PQB304
PQB305
PQW306
The connected parameters for motor 2 are:
PIB288
PID292
PQB288
PQB289
PQW290
etc..
How can I indirect these with integers or other ways... ?
Else I need to call the function to many times...
Its quite a major rewrite to convert the function from the current in/out parameter list.
I take it you just want to specify a Start address, and have all the other values follow on eg. last parameter would be PQW(Start + 2).
You need to read up on indirect addressing in S7, as one way or another you would end up creating a series of pointer from the specified atart address.
How many times is the function called? Is it worth a rewrite to save entering a few parameters, or are you worried about typo's etc.
Here's one possibility, pass in a pointer to the base address of the peripheral area and then use indirect address to access the areas you require.
hey
2 things...
first I don't really understand what you're doing with the w#16#FFFFFFFF ?
Second, I tried to implement you're code, but I'm seeing some probs. I use the read or the write block, check my code. Not really easy to do this.
Code:
[SIZE=2]
FUNCTION_BLOCK "LENZE_PKW"
TITLE =LENZE
VERSION : 0.1
VAR
READ_REQ : BOOL ;
WRITE_REQ : BOOL ;
MEMBIT_1 : BOOL ;
END_VAR
BEGIN
NETWORK
TITLE =LENZE PKW READ
A "DB M201 PKW".WRITE.REQ;
ON "DB M201 PKW".READ.REQ;
JC NEX1;
A "DB M201 PKW".READ.REQ;
A "Puls_Clk";
= #READ_REQ;
CALL "LENZE_PKW_READ" , "IDB_LENZE_PKW_READ" (
READ_REQ := #READ_REQ,
PAR := "DB M201 PKW".PARAMETER,
IND := "DB M201 PKW".INDEX,
Byte_1_Status := PIB 304,
Byte_5_6_7_8 := PID 308,
Byte_1 := PQB 304,
Byte_2 := PQB 305,
Byte_3_4 := PQW 306,
READ_VALID := "DB M201 PKW".READ.VALID,
READ_VALUE := "DB M201 PKW".READ.VALUE);
NEX1: NOP 0;
NETWORK
TITLE =LENZE PKW WRITE
ON "DB M201 PKW".WRITE.REQ;
JC NEX2;
A "Puls_Clk";
= #WRITE_REQ;
CALL "LENZE_PKW_WRITE" , "IDB_LENZE_PKW_WRITE" (
WRITE_REQ := #WRITE_REQ,
Byte_1_Status := PIB 288,
WRITE_VALUE := "DB M201 PKW".WRITE.VALUE,
Byte_1 := PQB 304,
Byte_2 := PQB 305,
Byte_5_6_7_8 := PQD 308,
WRITE_VALID := "DB M201 PKW".WRITE.VALID);
NEX2: NOP 0;
NETWORK
TITLE =PROGRESS READ / WRITE
JC NEX4;
A "DB M201 PKW".READ.VALID;
O ;
A "DB M201 PKW".WRITE.VALID;
JCN NEX3;
A "Puls_Clk";
FP #MEMBIT_1;
JCN NEX3;
L "DB M201 PKW".PROGRESS_BAR;
L 10;
+I ;
T "DB M201 PKW".PROGRESS_BAR;
NEX3: L "DB M201 PKW".PROGRESS_BAR;
L 100;
>I ;
JCN NEX4;
L 0;
NEX4: A "DB M201 PKW".READ.REQ;
O "DB M201 PKW".WRITE.REQ;
BEC ;
L 0;
END_FUNCTION_BLOCK
[/SIZE]
There is a certain hazzle with having to enter the adresses by hand to each of the FB's/FC's. However, one shall consider carefully if going 100% indirect just to save the typing time is a good idea.
In my projects I typically have 50-100 "objects" for which I must go through the boredom of writing symbols, defining alarm texts, generating IDB's, and entering the right symbols on the right I/O pins of the FB's. It is one or two days of boring typing, and I really hate this part.
However, the end result is code that is easy to read and troubleshoot.
I agree with what you're saying, I think I will copy the code 15 times (15 motors) and adjust the adresses in each copy, then jump to the code that I need to run, if it wasn't connected to a faceplate in WinCC Flex, It wouldn't be such problem, but I don't like to change very much.
2 things...
You should notice that it is W#16#FFFFFF and not W#16#FFFFFFFF.
The first one will result in changing from Area-Crossing indirect adressing to Area-Internal indirect adressing.
While the second doesn't do anything.
Area-Crossing is:
Code:
L P#IW304
LAR1
A [AR1,P#0.0]
= "some_bit"
Area-internal is:
Code:
L P#304.0
LAR1
A I [AR1,P#0.0]
= "some_bit"
Look at the screenshot from L D, look at the contents of ACCU1 and AR1.
Edit: Seems those puzzles are starting to pay off.......lol
How I understood this:
L P##pBaseAddress
-->load acc1 with memory location where this pointer begins, here V21.0
LAR1
-->point ar1 to this address, V21.0
L D[AR1,P#2.0]
--> Now load acc1 where this pointer store, start of the memory area passed to FC1, here PIW304 or 80000980 (thats why p#2.0)
AD DW#16#FFFFFF
-->Remove 80000 and keep only 980 or 304(304 is pointer equivalent in decimal format)
LAR1
-->load ar1 with 980 or 304 (use this number to refer different part of which ever memory area)
thanks
Thanks...
I still will avoid indirect stuff where I can, this makes the program less readable.
anyone know of any manufactures that would have such a device. I am building a test system that is both PLC and LabView based and I need a Megger...
469
I have a few old HP programmable power supplies - HP 6033A's. I'd like to control them from a CompactLogix 1769-L33ER. The power supplies have a...
2,608
Hello all, I'm hoping someone out there can help me. I have 2 plcs where I work which communicate with each other. In one of them it transfers...
5,052
Not sure if this is the right place to post this, but wanted to see if this software was still worth anything to anyone. My father recently...
3,610
Hi there! Does any of you have a program available for copying PIB data to a DB. What I need is: L PIB 512 T DB201.DBB0 L PIB 513 T...
5,541
