pico experts?
Ken Moore
May 2004
North, West, South Carolina
3,479
I have several of the ND (non-display) pico units being used as timers for agitators, been running fine for quite some time. After reading the pico user manual, I know that the ND model will read the memory module at start up if it has one. The question is, how do you write to a memory module with a ND model. All the user manual instructions are written for a display model.
My goal is to "burn" the program onto a memory module, all the units are running exactly the same program, then if one dies in the middle of the night, the maint. department can just swap it out and plug in the memory module, the program will be loaded from the module to the pico and I don't get any phone calls.
thanks,
Ken
I have one with a display that I use to write code and save to an EEprom. Then use the EEprom to download to the ND models.
You can probably use Software also, but I haven't tried it.
I bought the cable, and have been using the software all along. Just wondering if I missed something somewhere, when it came to writing to the memory module with a ND model.
Where can one safely download the AB Pico software? What cable is needed to connect to PC?
1,918
Hi im trying to connect my pico to my laptop but I cant configure the com port for usb. it works okay on a different laptop with the serial cable...
2,063
Hello, I am having trouble getting online with an old AB Pico module. I am currently using the 1760-CBL-PM02 cable, and cannot autoconfig via...
1,376
So I’m trying to write a program for a small stand alone press. We had some pico controllers in stock and figured it would take care of what i...
2,733
I wrote a small program the other day (4 inputs, 5 outputs) for a piece of equipment we have. A simple shackle bender with 2 limits, a footswitch...
1,325
