Bit_Bucket_07
You put a PID in place to control the flowrate. The "root problem", as you call it, is nearly always there, which is why you spend a lot of time and effort configuring and tuning control loops to regulate flow, pressure, level, current, speed etc., etc.
The purpose of a PID controller is to allow closed loop control without the need for constant human intervention. The PID controller is not capable of overcoming the laws of physics, and is not intended to provide a software patch for a hardware problem. If a process is so dysfunctional that it cannot be controlled by a highly skilled operator, then resolving the mechanical dysfunction within the process is the appropriate solution.
On the other hand, it is entirely possible that the application in question does not actually require that the PV never deviate more that +/- 1% of SP in order to be functional. All I know is that the top poster has stated that this is the desired goal.
