matt.smith71
Hello all,
Last time I did a PID loop was in V20 and that was probably eight years ago. It was a temp control application using a proportional valve.
I'm working on one now that on paper sounds easy. Use a pressure transmitter input (PSI) and adjust a pump speed via 4-20mA analog output to maintain the line pressure. System uses two pumps (one primary and one standby) but the loops should be identical as only ONE pump can be running at a time.
My current thought is to use the pressure feedback as the PV with the VFD Speed as the CV and a manual pressure setpoint. For some reason I don't think that looks quite right.
Any help would be appreciated, or if I'm barking up the wrong tree.
