kamenges
Originally posted by ViperDaSnake:
The payback on this...
You really didn't tell us what you expect the payback to be other than personal satisfaction. What detrimental equipment, throughput, quality or economy issues are you trying to correct? If you are just changing it so your fancy new analog controls don't act in a digital fashion then the payback is simply personal satisfaction.
The push of this post is to make you do a cost/benefit analysis. If you can define what detriment you are trying to address, you can put a cost to the detriment and then attach a cost you are willing to pay for a solution. For example, does the high rate of make-up infeed flow to the boiler thermally stress it enough that you expect a fatigue failure? If so, how long before it happens and how much do you expect this to take off the life of the equipment? There is your detriment cost or, more correctly, your benefit point. If the cost of better control is much less than this then add the sensors you need and move on.
Keith
