will work on getting rsp file for open loop test on equipment.
we just need the RSP file – not necessarily the file while the test is being run ... just save the file – then zip it and attach it to a post right here in this thread ... NOTE: some forum members (including myself) will NOT use a "dropbox" type address to recover your file ...
here's the reason why we want the RSP file:
90% of PIDs are set up wrong ... the scaling and the timing/triggering are the biggest culprits ... until we are sure that the PID is set up correctly – trying to get the "tuning" part right is pretty much just a waste of time ...
attaching file related to tuning furnace using Z/N method.
we don't want to see any tuning at all ... in the open-loop test that we're requesting, the PID is out of the picture (or at least, running in a MANUAL or SET OUTPUT mode) ...
basically you crank in a value for the output (say 10%) and let the system settle (repeat SETTLE) out to a steady state ...
then you crank in a new higher value for the output (say 80%) and let the system settle (repeat SETTLE) again ...
record the initial – and the ending – values for CV and PV ... and make sure that your graph shows the time scaling too ...
examples:
an initial setting of 10% CV gives 115 DegsF for the PV ...
an initial setting of 80% CV gives 375 DegsF for the PV ...
total graphing time is 22 minutes ...
(again - these are EXAMPLES - your values will vary) ...
you can see the types of measurements that we plan to take from the graph in this post:
http://www.plctalk.net/qanda/showthread.php?p=27701&postcount=6
if the open loop test is properly done, it will give us a LOT of information about the characteristics of your system ... then we can base our "ball park" suggestions for your tuning values on the results of the test ...
personally I'm having zero luck opening the PowerPoint picture that you posted ...
it would be better to run a simple TREND in RSLogix5 and then do a screen shot of that ... then attach it to a post as a PNG graphics file ... (ask if you don't know how) ... the graph attached to my first post (#23 above) would be an excellent example to follow ...
