shown below are my notes (questions) from your "part3" figure ...
I'm just guessing – but did you just "sketch in" the Control Variable (% power) trend? ...
suggestion: click the link below my signature – get my email address and send me the RSP file ... then give me a call (the phone number is available through the link) and I'll try to help you with this ...
you've also made a note on your "part4" figure that is troubling ... you mention that some "heavier than standard parts" were run through the furnace during the bump test ... that's a problem ... the purpose of the bump test is to experimentally ascertain the characteristics of the process ... it's ok to have a "load" on the system – but the load should remain STEADY throughout the test ... specifically, CHANGING the load during the test will defeat the purpose of the experiment ...
anyway ...
I've got a little bit of spare time today – give me a call if you like ... (it would be best if I had the RSP file for about ten minutes before you call) ...
PID values calculated from bump test were tried out. results shown in attached graph for before and after change. new values are causing excessive oscillations.
