Pide instruction control logix
Britt
Mar 2011
GA
Manual tuning this instruction as with older pid's " set Kp until oscillates and half it then increase Ki until offset is correct to sufficient time and leaving Kd at zero" has not been to successful. The auto tune button works about as well as any other I have seen. Any info. on how to achieve this faster please do tell.
I haven't had any particular problem tuning PIDE's, (remember to hit "Apply" after EVERY change), but the PIDE instruction is much less reliable then the old standard PID instruction.
Do you absolutely need the (somewhat dubious) enhancements the PIDE instruction provides?
Hello All, Looking to get a better understanding behind an issue that I had earlier today with a PIDE Instruction that was not changing it's CV...
1,298
Hi: I have a process where I need to control flow with a bomb with Powerflex700. I have a periodic PIDE instruction, Flowmeter is the PV and CV...
16
5,166
Hello, I am running a PIDE instruction and its running OK but when i open the PIDE properties of the instruction, its status shows InstructFault...
4,571
Hi, In one of our project, we are using PIDE Instruction block (FBD) for all closed loop controls operated through MMI. In that, when the...
8,059
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
175
