PID's Factorytalk ME and RS5000 help!
dginbuffalo
Dec 2010
Buffalo,NY
630
Hello,
trying to set up some PID loops with ME and 5000. i'm fairly new to both. i'd like to use a faceplate and PIDE function block-spinning my wheels. can i just drag and drop a faceplate in from the library? and what bits do i have to fire in a PIDE to run it in manual? holy cow is there a lot more options then just the .swm in the old Logix 5!! any other suggestions on a good PID faceplate or window setup? i want to be able to go to manual/auto, change sepoints or CV while in manual.
Anybody know how to make FactoryTalk license server automatically look for a dongle on startup instead of your hard drive? I have to configure the...
2,394
91
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
100
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
628
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
975
