Pilz PNOZ Multi Ethernet IP to Controllogix integration
Chibu
Feb 2023
Ontario
49
Hi Guys,
I'm trying to integrate Pilz Ethernet IP Module to ControlLogix.
I added Pilz module as a Generic Ethernet module and I'm able to read/write Boolean but I can't see analogue values from Pilz to Controllogix.
Please, if you have done this before, could you share some light?
Which Pilz safety controller and comms module are you using? Which analogue values are you referring to? You may want to check the comms manual for "Advanced Data". If you can read/write bits then your comms are working, so you may need to look at how the I/O is assigned.
Controller: PNOZ m B1 Burner, Product number: 772102
Comms Module: PNOZ m ES EtherNet/IP, Product number: 772137
Analogue Values: Transmitters connected to the Pilz, these data need to be viewed from Pilz to ControlLogix then to FTV SE
I have read through the Advanced Data information but I'm still stuck, could you please tell me how the Data ID e.g 0x40 for Analogue Input i0; mA; float IEEE 754, can be used to integrate/see the Data in Controllogix?
Hi All, I'm currently working on a project where I have to set up ethernet comms with a Pilz PNOZ Multi M1P Eth from AB L72 PLC. I have it...
5,044
Dear All. I need comm between Compactlogix/Controllogix with PNOZ m1p ETH. What we need the communication option? or can be connect direct? many...
1,180
WANT TO KNOW ABOUT PILZ PNOZ S3 WIRING & FUCTIONS:teacher:
1,817
Thoughts? Anyone had any transitional experience from one to the other?
3,049
Hi, Dear friends. in my PILZ PLC PNOZ m1p FAULT indicator is ON, PLC not running, i downloaded demo software from PILZ website. it has one D...
6,365
