Playing with devicenet some help reqd.
504bloke
Jan 2005
Down South
2,721
Ok
Just playing with devicenet rsnetworks and setting up a 1747-sdn scanner for mapping a 590+ SSD DC Drive
I will be using in this example
0x71 read 12 bytes as per ssd manual
0x66 write 10 bytes as per ssd manual
see attached for ssd manual page
One Question
On the edit IO Parameters in rsnetworks
which way do i read the Input and Output mapping
i have attached a photo, is this correct
ie
input size - 12 which corresponds to a read on the 590+ of 12 words ? or have i got this the wrong way round! ??! ?
Thanks in advance
I think you have it right.
The Scanner Module configuration window in RSNetworx for DeviceNet can be forgiven for breaking with the "Produced / Consumed" nomenclature that DeviceNet uses to be unambiguous about the direction that data is going.
In the 1747-SDN I/O Connection window:
Input Size: 12 Bytes This data is Consumed from DeviceNet by the 1747-SDN and placed in the Input data file of the SLC-500.
Output Size: 10 Bytes This data is taken from the Output data file of the 1747-SDN and Produced on DeviceNet.
So what does this mean relative to the Eurotherm documentation ?
Assembly 0x71 is a Read assembly. If the data is "read" from the drive by the DeviceNet adapter, then it is Produced onto the network, then Consumed by the 1747-SDN, and becomes Input data in the SLC.
Assembly 0x66 is a Write assembly. If the data is taken from the Output data table in the SLC, is Produced onto DeviceNet, then Consumed by the Eurotherm interface, it may be Written to the drive.
Verbs are so much fun !
Where did you get that user manual ? If I can read the whole thing it might make more sense to me.
Heres the user manual
It does document an RSNetworx example, but the screens show Rx and Tx which i presume is an old software version?
Also if i map 12 bytes of input from the drive to the scanner it shows on the scanner input table as only 6 ? ie I:1.1 through I:1.7
A little confused ?
I cant attach the manual as its >300K but heres a link
http://www.ssddrives.com/usa/doc/HA463575.pdf
Andybr said:
I am sure that you have already realised this but 12 bytes = 6 words.
ie I:1.1 - I:1.7.
Duhhh
Had a slight brain blockage :(
All cleared on the bits, bytes and words now !
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
342
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
133
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
764
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
605
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,077
