plc 115vac input
rick62
Jul 2013
tuscumbia al
45
I keep losing this input on an dl06 automation direct plc, all inputs are 115vac, all of the other ones are ok, just one that I have had to move twice to another input- what is the best way to protect your 115 vac inputs from failing.
What is that input coming from? Can the device you're monitoring create an inductive spike when it turns off? Can you use an interposing relay on that input?
A properly rated MOV in parallel with the input, and connected to ground may help.
-rpoet
Since we're talking about it, can anyone recommend a MOV or snubber they'd recommend to put across the coils?
I tried picking one out on Mouser a few weeks ago, but all the choices are overwhelming.
kindly need to understand why can't upload the plc
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
225
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
193
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
44
