PLC - 3 Level Elevator
nicoise
Jun 2014
Poland
Hello, i am in plctalk.net :) I need little help. These wiring diagram and ladder diagram for s7-200. Can someone convert these two diagrams for s7-1200 ? I will be very grateful. If it is necessary i can translate to English writings what is on diagrams.
[FONT=&quot][/FONT]
you can just type it over, as 200 is same as 1200, it are the input and output cards that are different so maybe you need some address change.
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
643
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
704
I posted how computers work at the fundamental level on Reddit if you want to check it out. Pretty fun stuff and thought I would share it here as...
3,169
We've got a submersible water level sensor in our tank. We drained it, but when there was still a bit of water in the tank (about 20mm measured...
2,813
Hi, I am just exploring the options to replace an outdated filling valve controller for a can filler. It has 78 filling valves and runs at max...
4,538
