Malti Member M Join Date Oct 2008 Location Ontario Posts 5 Oct 26, 2008 #1 I have an AB PLC 5/15, Processor: 1785LT. rev M, Ser A. I would like to communicate with this through my laptop. What cables, hardware do I need?
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Oct 26, 2008 #2 Your processor has DH+ and remote I/O comms. Your only choice to communicate with your laptop is DH+. The 1784-PCMK card will work ( PCMCIA card) Or the older 1770-KF2 box , this is a serial to DH+ device. There are some third party devices, search Google should turn up something. http://www.protocolconverter.com/products/dl3500dh+df1.htm Last edited: Oct 26, 2008
jstolaruk Lifetime Supporting Member J Join Date Dec 2004 Location Detroit, SE Michigan Posts 3,912 Oct 26, 2008 #3 And if you intend to program it you'll need programming software - Allen Bradley's RSLogix 5 and RSlinx.
Malti Member OP M Join Date Oct 2008 Location Ontario Posts 5 Oct 26, 2008 #4 Thank you for your speedy replies: I will try to locate the 1784-PCMK card locally.
controlled Lifetime Supporting Member C Join Date Nov 2005 Location bowmanville Posts 419 Oct 26, 2008 #5 Malti said: Thank you for your speedy replies: I will try to locate the 1784-PCMK card locally. Click to expand... be prepared for "Sticker Shock" Those cards and cables are very expensive
bkottaras Member B Join Date Oct 2005 Location Chicago Posts 1,802 Oct 26, 2008 #6 controlled said: be prepared for "Sticker Shock" Those cards and cables are very expensive Click to expand... In addition, I'd stick with Win XP Pro SP2, since I have used the PCMK without any issues. Not sure if SP3 will work. And get a Series "B" if you can. Series "A" are a but flaky depending on the OS.(worked well with older OS and carware)
Malti Member OP M Join Date Oct 2008 Location Ontario Posts 5 Oct 29, 2008 #7 Thank you for your help, I got the 1784-PCMK card & 1784-PCM5 cable, both are series B being used on XP SP2: Working great so far. Thanks again.
