PLC-5 1771-DA Module
Ken Roach
Apr 2002
Seattle, WA
17,482
A question was sent via PM this morning from a new member (Vince9521, from up in Timmins, Ontario) that I'm promoting to the main forum:
plc-5 1771-DA,
I am trying to set up the card but from what I read I need to initialize the card but am i able to do that with out the special programmer. Or can I initialize it with the processor and data files ?
The 1771-DA was an ASCII communications module from the early 1980's that was used with PLC-2, PLC-3, and PLC-5 Classic controllers. With the advent of the Channel 0 serial port on the PLC-5 Enhanced and the more capable 1771-DB BASIC52 interpreter module, the 1771-DA declined in popularity.
My recollection is that it was configured and controlled entirely by ladder logic and Block Transfer instructions. I don't think there is a "terminal mode" or menu-driven configuration function.
The User manual is available from the RA Literature Library, but because of its age the step-by-step instructions focus on the PLC-2 and PLC-3.
https://literature.rockwellautomation.com/idc/groups/literature/documents/um/1771-um513_-en-p.pdf
What is your goal: are you trying to repair or troubleshoot an existing system, or are you trying to program one of these modules to add features to a PLC-5 system ?
Post as much context and detail as you can about your processor (model of PLC-5) and application (what's connected to the RS-232 port ?).
And again, welcome to the PLCTalk forum community !
Hey everyone, Trying to bench test the I/O on a program that I converted from a PLC-5 processor to a ControlLogix processor but still using the...
21
6,520
I am doing a little self training and looking for some feedback. I have a plc 5 with a 1771-il module looking into some scaling issues with an...
1,396
Hi, We have a customer using PLC-5 system with RIO. From what they complain is the slow speed of the PLC DI (normal), thus they wanted to get...
17
10,452
These two RTD's are wired to channels 1 and 2 on a 1771-IR in a remote rack, communicating to a PLC-5/40 through an ASB. I believe that the RTD's...
1,966
Hello, I am in the process of migrating a PLC-5 system over to ControlLogix and could not find any equivalent modules to convert the 1771-ALX...
1,490
