PLC 5 1771DB to CLX
NBJamie99
Jun 2008
Ohio
32
I have been asked to quote a PLC upgrade, in which the customer wishes to replace the current plc 5 processor with a RIO module, and add a new control logix rack. I believe I have most of this under control, from various searches here and on Google.
But... The existing rack has a 1771-DB module, which the customer has the DRS file for, but leads me to my question.
Q1. It appears the PLC 5 was accessing data from the 1771-DB the same way it does from an analog IO card (BTR, BTW). Would I be safe to assume that I should be able to handle this in Logix the same way as analog IO with messages?
If it makes any difference, to my knowledge the module only has a connection on the RS-232 port.
Thanks in advance.
Details: 1785-L80B processor. 1 DH+ connection, and 3 RIO channels.
If anything else is needed, I would be happy to provide it.
Yes in general it's the same BTR/BTW interface. I've done the same conversion you have where the customer had old ASCII scales attached via RS232. Seems like mine only required BTR since there was no configuration data.
I have been asked to quote a PLC upgrade, in which the customer wishes to replace the current plc 5 processor with a RIO module, and add a new...
5,252
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
37
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
65
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
45
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
84
