PLC 5/25 download program
I've used a powered off PLC-5 Enhanced processor as an adapter. On channel 1A, connect U2DHP mini-din. To the linked Channel 1A pheonix connector run blue hose to the pheonix connector of the PLC5/25.
Just a little on the pricey side for an adapter, but a unique solution.
If you had an enhanced PLC5 laying around, why would you not replace the PLC5/25 with it? ( just asking)
Mickey,
I'm not the OP, just giving a suggestion. He has a U2DHP mini-din, and possibly a PCMK with a mini-din, so he must have a device (like a PLC5 Enhanced) to plug it into. Even if one has to shutdown another line temporarily to borrow the processor to use as an adapter it may be worthwhile.
As far as my usage, I wanted to connect to a Datahighway connected to Channel 2B on our processors, where there is no mini-din port, So I added a tap so I could connect to my U2DHP to use NetDecoder.
Speaking of PCMK, I believe mine has a 9pin-mini-din connector at the end. I don't know if they all do.
good afternoon: we had Mitsubishi PLC memory lost. we got the program from OEM, the program file looks like created by GX Developer, we called...
1,893
Ok so I assume the answer is no, because it's AB. Other Manufactures have small utilities for this. Is there any way I can "Download" a program...
3,857
Is there a way to download PLC program from a server through batch file or by script? i would like to download different application depend on my...
3,601
I am unable to download the program on a Schneider Quantum PLC via USB connection. I have tried using Unity pro XL, and Unity Loader. But still no...
2,749
Hi.can i take back up from ps4-341 moeller cpu that don t have memory card.It seems that i can t .and then how i can remove plc error . ( plc in...
1,225
