plc 5/40e ethernet
hi, I observed that PLC 5/40E is not observing its subnet configuration. If i put IP address of range 192.x.x.x it assumes its c class and if I...
1,346
Can i do that?? I have been searching but i just found that i can do that but with a RIO Flex IO using the 1794-ASB. Is there a way to make the...
5,335
Hi All, I am working on a project where I am integrating two different PLCs on a single network. I want to know how can I access I/O points of...
3,485
okay i have a plc 5/40e that is programmed from a scada running rs logix 5 ver(5.2.3) we programed the ip address for the plc with DH+ for channel...
3,280
G
I have a PLC 5/40E that I would like to put on an Ethernet network. What do I use to go from the 15 pin Channel 2 to RJ45 connection? Where can I...
2,453
