PLC 5/40E Ethernet
Guest
Guest
G
I have a PLC 5/40E that I would like to put on an Ethernet network. What do I use to go from the 15 pin Channel 2 to RJ45 connection? Where can I buy one locally in the Portland, OR area?
You will need device called AUI twisted pair transmitter.
You should be able to find it in most of computer places and Radio Shack.
AB sells one also: 1785-TR10BT
MANUAL
The last time I needed an 10BaseT/AUI transceiver, I bought a handful of old Bay Networks units for two bucks apiece. I'm still using them with PLC-5E's.
You should be able to find these inexpensively at any computer shop, even at a secondhand PC shop because they're fairly old stuff.
What's a lot harder to find is an AUI extension cable (if you don't have enough panel depth in front of the PLC-5), but even that is not impossible to find if you know what it's called.
You can find the part you need in the Black Box catalog.
Their part # is: LE2041A-R4
We usually use a cheaper generic version though.
Like the other guys said, these can be had for less money if you know where to look.
hi, I observed that PLC 5/40E is not observing its subnet configuration. If i put IP address of range 192.x.x.x it assumes its c class and if I...
1,344
Can i do that?? I have been searching but i just found that i can do that but with a RIO Flex IO using the 1794-ASB. Is there a way to make the...
5,335
How do I find the ip address of the processor? I don't see it written anywhere! Thanks in Advance.
1,518
Hi All, I am working on a project where I am integrating two different PLCs on a single network. I want to know how can I access I/O points of...
3,485
okay i have a plc 5/40e that is programmed from a scada running rs logix 5 ver(5.2.3) we programed the ip address for the plc with DH+ for channel...
3,280
