PLC 5/60 processor fault
**Bolty** said:
Morning all, Just a quick bit of follow up to let you know the conclusion of my plc 5/60 processor fault.It was the 1771-p7 power supply at fault. I checked status table, dip switches on both rack and processor, retested battery and connections. Reseated processor, modules etc but none of these made any difference.Program would still disappear.
I then swapped out the processor, loaded the program, powered down and again no program on power up. Swapped back the old processor, then swapped out the power supply and loaded in the program again. Powered down the panel, counted to ten (heh) then powered up and voila, processor on a steady green and the program still there!!.
So, thanks all for the suggestions, especially the dip switches. Would never have thought of that as a possible fault, but a pint goes to mickey for getting the correct fault although you'll need to come over here to get it though.
Cheers all
Bolty.
Pint?? Maybe a few liters of Scottish Ale.
http://www.allaboutbeer.com/style/24.5-scotchale.html
heh..ok maybe the offer of a pint was a bit stingy. I'll get you a gallon of 70 shilling (Special) or 80 shilling (Heavy).
Cheers (hic!)
Bolty
We have a AB PLC 5/??? showing fault LED RED ON. Operator does not seem to be able to change set point on PIDs and PLC is not responding to these...
4,330
Hi, I had an issue with a PLC 5/15 showing a solid red light for the processor status. I think this indicates a hardware issue. The funny thing...
3,450
Good Evening . I visited a pump station sight today that has a PLC-5/11 CPU. I was given a CD with only a file with a program and extension of...
3,772
Hi friends, I am AVI , working on Schneider electric make M258 PLC. While communicating it with SO machine software v3.0, facing problem...
1,325
Hey everyone, I can't seem to find good instructions on how to connect/set up a brand new PLC. Thanks for the help.
2,711
