PLC 5 calculate tons of slurry in silo
remullis
Oct 2012
Georgia
179
We currently use a level indicator in silo's where I would like to also give the operator tons of slurry based on the percentage of tank filled.
What instruction would be best suited for scaling say a 3393 cuft tank in relation to percentage full? This will be done in a plc 5 and possibly contrologix.
rm
Depends on the shape of the silo, right ?
Calculating volume based on height of the contents is a classic math problem that level transmitters have solved with creative setpoint and model settings.
In a PLC, you have plenty more math instructions. For a flat-bottomed cylindrical silo, it's just the area (a constant you can calculate) multiplied by the height (a value you're measuring) times the mass-per-volume for the slurry.
The geometry gets a little more complex with a round-bottomed or spherical tank, of course.
Ken,
Right, so I know that my tank volume is 3393 cuft. I currently know where my level is, for example 15'0 in a 30' tank. What instruction could I use for scaling the 15' to 1/2 of 3393 cuft. I think I have the math figured out for tons in the 3393cuft tank. 15' would give me 1696.5 cuft x density = tons of slurry.
Will scaling with parameters convert the level in the tank to cuft if I know the volume of the tank? Or is there a better method?
I just realized SCP function is not used in a PLC5. What I want to do is scale.
Tank level 0-30'
and be linear 0-3393cuft, then cpt the cuft*density.
Tank level 0-30'
Tank level * 113,1 = cuft (if linear, flat bottomed silo and tank level is measured from bottom)
Hi, I've been asked to display the pump efficiency on our HMI system (iFIX). They have requested a kind of bar graph to indicate if it's running...
2,453
For example, I want a PLC (US$1000) to calculate 1 divided by 9. Can I expect the PLC able to handle a 4 decimal points of calculation? Thanks
2,636
Can anybody tell me How to Calculate the MTBF- Maen Time Between failure PDF - Probability of undetected failure per hour PFD - Product...
4,015
hi I want to calculate speed rotation (RPM) with Omron PLC using a optical or proximity sensor. Thank You in advance
9,559
Dear All, Back to college days, can anyone give me a simple formula to calculatr a Heat dissipation of the PLC / DI / Do / AI cards / modules...
54,757
