how to calculate MTBF of a PLC system
omsumitam
Jul 2009
New Delhi,India
23
Can anybody tell me How to Calculate the
MTBF- Maen Time Between failure
PDF - Probability of undetected failure per hour
PFD - Product Probability of failure on demand
of a PLC system. formula or Link
If i am using a URL base communication b/w two distant scada based Engineering System and using a Redundant Internet connection of say Airtel and Vodafone. then is it possible to calculate the MTBF of Communication offered .
Thanks in advance.
I am sure that someone can, but....
If the algorithm does not account for errors in implementation AND abusive users, it will not be very accurate.
Nearly all failures I've seen in more than 30 years have been "user" triggered in some way.
I have seen two lightning triggered failures...o_O
Thanks to all ,for your responses
If considering "Lightning" could be a failure cause and still i go with GSM/GPRS Modem for communication b/w two control stations who are 70KM .Can you help me out of the these :
LIMITATION of Following:
1. GSM modem between two Control Stations without repeater if specification are
2W @ 800-900MHz
and 1W @ 800-1900MHz,
Freq.-800,900---,1900 EGSM
2. Shielded Twisted Pair of say 6 Pair x 1.5 sq.mm underground 900mm-1 meter in terms of EMC (Electro Magnetic Compatibility)or ETL .
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,036
Good morning, I have a question. I don't know much about ST yet I would like to calculate the average number of products per hour. how do I do...
22
2,970
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,110
I want to calculate the energy consumed from instantaneous power. Can this be done using the TOT block with timebase set to Hour?
696
Hi everyone, I have to calculate the length in millimeters of a glass that enters a transport (I don't know the speed yet) through a barrier...
3,468
