PLC-5 Data Concentrator - What is it?
skyfox
Nov 2006
CA
279
Just came across a configuration that I am not familiar with. In this configurartion, there are several PLC 5/40E rack with local analog I/O cards connected via a DH+ network. Some of the racks are referenced as regular plc's, while the others are labeled as data concentrators. All of the racks have CPU modules in them.
Can someone kindly explain.....
1) The difference between the two?
2) Purpose/benifts for configuring a rack as a data concentrator?
3)Is there a difference in data (block) Transfer between analog modules?
ie. PLC CPU/Analog I/O in local rack data transfer vs Analog I/O in data concentrator rack to it's local CPU?
I googled "PLC5 data concentrator" and found a few interesting references.
It seems it is a normal PLC but it's utilization is specialized.
Maybe something more like distributed control and communications? The predecessor to the contrologix gateway? I did not follow the links, but they should hopefully help...
Paul
There's nothing unusual or special about those controllers; the term "data concentrator" is just the label someone has given them.
Often I see a controller called a "data concentrator" when it is gathering data from its serial port
via DF1 Half Duplex or using Modbus modules, then is accessed by a LAN connection over DH+ or Ethernet.
In our case, we have a Data Concentrator which gathers data from 5 networks. Then our Scada system polls the data concentrator rather than the expansive network of PLC's.
The term data concentrator can mean anything - nothing special. My interpretation (as probably most others) is that it is a centralized repository of remote data.
Thats exactly what i would describe it as too, it just polls the other PLC's on the network for data then SCADA only has to look at one device
Good afternoon everyone. A while back I asked for input regarding the use of a PLC to act as a 'data concentrator' as an...
17
10,370
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
82
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
105
I am working with beckhoff plc in twincat 3 environment. I have a array of struct which I want to make persistent. I declared it with...
114
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
301
