PLC-500 ICOM Software & SLC-500 plc
Boot the computer in safe mode, and see if RSLinx will run. Check the setup for the driver. Delete and recreate. I remember it was fairly easy to set up the driver wrong as the default was not the PCMK module , but the PKTX.
Here is the error dump:
Application exception occurred:
App: rslinx.exe (pid=580)
When: 11/5/2013 @ 13:50:15.766
Exception number: c0000005 (access violation)
*----> System Information <----*
Computer Name: PENTIUMLAPTOP2
User Name: SYSTEM
Number of Processors: 1
Processor Type: x86 Family 6 Model 5 Stepping 2
Windows 2000 Version: 5.0
Current Build: 2195
Service Pack: 4
Current Type: Uniprocessor Free
Registered Organization: Prepair Ltd
Registered Owner: Peter A Forbes`
*----> Task List <----*
0 Idle.exe
8 System.exe
148 smss.exe
168 csrss.exe
188 winlogon.exe
216 services.exe
228 lsass.exe
380 svchost.exe
416 svchost.exe
476 spoolsv.exe
500 MWMDMSVC.exe
528 MWSSW32.exe
596 jqs.exe
624 mxserver.exe
748 regsvc.exe
764 MSTask.exe
824 WinMgmt.exe
876 svchost.exe
1128 Explorer.exe
636 PPControl.exe
664 PPMemCheck.exe
672 CookiePatrol.ex.exe
948 tphkmgr.exe
1144 jusched.exe
1176 internat.exe
1232 {461ADABA-A9D1-.exe
1248 MSSTAT.exe
980 WPC11Cfg.exe
1116 msiexec.exe
924 OPCENUM.exe
484 RSLinxcp.exe
1064 RSOBSERV.exe
580 RSLINX.exe
1288 drwtsn32.exe
1284 taskmgr.exe
0 _Total.exe
(00400000 - 00588000)
(77F80000 - 77FFC000)
(67DE0000 - 67E08000)
(7C570000 - 7C624000)
(77E10000 - 77E6F000)
(77F40000 - 77F7D000)
(7C2D0000 - 7C335000)
(77D30000 - 77D9F000)
(779B0000 - 77A4C000)
(7CE20000 - 7CF0F000)
(67C60000 - 67C68000)
(77820000 - 77827000)
(759B0000 - 759B6000)
(67EA0000 - 67EA7000)
(6C370000 - 6C46B000)
(78000000 - 78045000)
(10000000 - 100D5000)
(7CDC0000 - 7CE10000)
(7C340000 - 7C34E000)
(77BF0000 - 77C01000)
(77980000 - 779A5000)
(75050000 - 75058000)
(75030000 - 75044000)
(75020000 - 75028000)
(77950000 - 7797B000)
(751C0000 - 751C6000)
(75150000 - 75160000)
(71710000 - 71794000)
(76B30000 - 76B6E000)
(70A70000 - 70AD6000)
(7CF30000 - 7D176000)
(77570000 - 775A0000)
(67EE0000 - 67FA8000)
(67EB0000 - 67EDF000)
(780C0000 - 78121000)
(00230000 - 002BA000)
(77800000 - 7781E000)
(76620000 - 76631000)
(002C0000 - 002D1000)
(681A0000 - 681A7000)
(66740000 - 66747000)
State Dump for Thread Id 0x198
eax=013f0048 ebx=000003f8 ecx=418b084b edx=00455845 esi=013f0040 edi=00f10000
eip=77fcc022 esp=0012fa7c ebp=0012fa94 iopl=0 ov up ei ng nz ac po cy
cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00000a97
function: RtlFreeHeap
77fcc00a 663b58f8 cmp bx,[eax+0xf8] ds:01e69f2f=????
77fcc00e 7604 jbe 77fd4b14
77fcc010 8b00 mov eax,[eax] ds:013f0048=00455845
77fcc012 ebf2 jmp 77fd4c06
77fcc014 8bd0 mov edx,eax
77fcc016 8b4a04 mov ecx,[edx+0x4] ds:00ecf72b=????????
77fcc019 8d4608 lea eax,[esi+0x8] ds:01e69f26=????????
77fcc01c 894e0c mov [esi+0xc],ecx ds:01e69f26=????????
77fcc01f 56 push esi
77fcc020 8910 mov [eax],edx ds:013f0048=00455845
FAULT ->77fcc022 8901 mov [ecx],eax ds:418b084b=????????
77fcc024 57 push edi
77fcc025 894204 mov [edx+0x4],eax ds:00ecf72b=????????
77fcc028 e88d14fdff call RtlIsValidIndexHandle+0x18fa (77f9d4ba)
77fcc02d 0fb7c3 movzx eax,bx
77fcc030 294510 sub [ebp+0x10],eax ss:00ba997a=????????
77fcc033 8bcb mov ecx,ebx
77fcc035 f6460510 test byte ptr [esi+0x5],0x10 ds:01e69f26=??
77fcc039 740b jz RtlInvertRangeList+0x92 (77fccf46)
77fcc03b 0fb65604 movzx edx,byte ptr [esi+0x4] ds:01e69f27=??
77fcc03f 8b549758 mov edx,[edi+edx*4+0x58] ds:00ecf72c=????????
77fcc043 897238 mov [edx+0x38],esi ds:00ecf72b=????????
*----> Stack Back Trace <----*
FramePtr ReturnAd Param#1 Param#2 Param#3 Param#4 Function Name
0012FA94 77FCAABE 000003F8 013F0010 000003F8 00000000 ntdll!RtlFreeHeap
0012FAC4 77FCA8A0 00F10000 00000000 00000002 00000000 ntdll!RtlCreateHeap
0012FB08 77FCB0A0 00F10002 00000788 012F0048 FFFFFFFF ntdll!RtlCreateHeap
0012FCE4 78001532 00F10000 00000000 00000780 012F0048 ntdll!RtlAllocateHeap
0012FD24 780014CF 00000772 780014B8 00000772 00000000 !malloc
00000772 00000000 00000000 00000000 00000000 00000000 !malloc
*----> Raw Stack Dump <----*
0012fa7c 40 00 3f 01 40 00 3f 01 - 00 00 3f 01 00 00 f1 00 @.?.@.?...?.....
0012fa8c 00 00 3f 01 02 00 00 02 - c4 fa 12 00 be aa fc 77 ..?............w
0012fa9c f8 03 00 00 10 00 3f 01 - f8 03 00 00 00 00 00 00 ......?.........
0012faac 00 00 f1 00 88 17 00 00 - 00 00 00 00 08 00 00 00 ................
0012fabc 00 02 00 00 00 00 f1 00 - 08 fb 12 00 a0 a8 fc 77 ...............w
0012facc 00 00 f1 00 00 00 00 00 - 02 00 00 00 00 00 00 00 ................
0012fadc 00 00 3f 01 00 20 3f 01 - fe 01 00 00 00 00 f1 00 ..?.. ?.........
0012faec 78 01 f1 00 f1 00 00 00 - 02 00 00 00 00 20 00 00 x............ ..
0012fafc 00 10 00 00 00 00 3f 01 - 00 00 20 00 e4 fc 12 00 ......?... .....
0012fb0c a0 b0 fc 77 02 00 f1 00 - 88 07 00 00 48 00 2f 01 ...w........H./.
0012fb1c ff ff ff ff a9 14 00 78 - 40 00 00 00 00 00 00 00 .......x@.......
0012fb2c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0012fb3c 00 00 00 00 00 00 00 00 - 20 00 1a 02 d0 21 13 00 ........ ....!..
0012fb4c 00 00 00 00 f0 7e 57 7c - 00 00 00 00 03 00 00 00 .....~W|........
0012fb5c fd 09 01 10 64 43 01 10 - 60 22 fb 00 88 50 fb 00 ....dC..`"...P..
0012fb6c 00 3b fb 00 00 00 fb 00 - 90 fb 12 00 81 d9 fc 77 .;.............w
0012fb7c ef 01 00 00 88 50 fb 00 - 00 00 fb 00 00 3b fb 00 .....P.......;..
0012fb8c 08 3b fb 00 00 00 fb 00 - 00 00 fb 00 78 01 fb 00 .;..........x...
0012fb9c 2b ba fc 77 08 06 fb 00 - b1 b9 fc 77 01 00 00 00 +..w.......w....
0012fbac 08 3b fb 00 01 00 00 00 - 01 00 00 00 01 00 00 00 .;..............
This line:
Peter
This is the hardware:
& this is what we get out of it at the end, this is a 110V rail battery test graph:
Thought that you may like to see the nuts and bolts.
Peter
Before wasting any more time with the 1747-40C, then seriously consider to just upgrade it to something more recent.
You have the offline program already. There seems to be no operator panel or any such things to complicate the matter. Just a few inputs and outputs.
My guess is that the conversion can be done in less than a day, and the expense is very little (any small PLC can do the job).
You have to do it sooner or later anyway, so ...
Were you able to get RSLinx to start in Safe mode?
I guess Mitsi is the future, but we still have to support existing equipment.
Just trying a few things out this end, might be able to get hold of a clean install of RSLogix and RSLinx if all goes well, then we can try again.
Thanks to all for the inputs, very much appreciated!
Peter
Hi Peter,
If you don't manage to get it sorted out then I might be able to put you in touch with a couple of ex Allen Bradley engineers in your area of the country, one in Coventry, the other in Leicester, they should be able to help you out with getting on-line.
But long term as JesperMP has suggested why not plan to upgrade, you might be surprised at how little it would cost to fit a modern Allen Bradley PLC and if you have the existing ladder logix it could be imported.
With a small modern PLC mounted on a baseplate drilled to to fit the existing SLC mountings, when one of your customers calls because their SLC is dead you could be ready to sell them a replacement / upgrade. May even be able to add some extra features.
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
113
Hello all, I have an ABB PLC (PM573) and it has without MC card. I need to take backup from PLC to PC (in automation builder v2.7 ). My...
541
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
400
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
851
Looking for options to write data to Siemens PLC. Looking for something closest to way we were doing it with AB PLC and excel sheet. Old way...
936
