PLC about coil winding machine
secretagent
Aug 2017
Turkey
Hi I can make the this pictures system. But my master motor AC motor and Slave Motor Stepping motor. I have the PLC and main motor shaft encoder.
I want to wrap the wire into the coil properly. I'm doing this somehow, but winding goes down when speed increases.. Can you help with the topic?
How should I follow an algorithm??
<a href="https://hizliresim.com/4jqrWJ"><img src="https://i.hizliresim.com/4jqrWJ.gif"></a>
hi; i'm new in the plc programming(ladder work) and i'm using CX-programmer(9.35) to program CPU(CJ1M-CPU12). input module :CJIW-ID262 output...
1,268
Hi, Can any of Siemens PLC expert please tell me; 1) Can we ever detect the first scan of the Siemen PLC whenever it RUN (either due to power...
5,597
kindly need to understand why can't upload the plc
43
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
39
242
