Siemens PLC 1st scan Coil and Time..
stevenPLC
Sep 2004
27
Can any of Siemens PLC expert please tell me;
1) Can we ever detect the first scan of the Siemen PLC whenever it RUN (either due to power shutdown and recover back, or PLC is started for the first time)? It's because I would like to initialize some value into certain registers whenever the PLC is started.
2) Where (any special FB or Register) and how can we monitor and read the PLC Time and Date?
Thanks for the info..
1) Yes. Set a bit in the startup block, evaluate it in OB1, and reset it in OB1. You could also evaluate the OB1_SCAN_1 variable in the temp data of OB1, but I find it easier to just set a bit.
2) Do a search on this site. There are plenty of examples and sample code describing how to access the system clock.
Hello StevenPLC;
Just to make S7Guy's statement, what he calls the startup block is OB100/OB101. Siemens calls them Cold restart/Warm restart 9look up the Step7 help files to find the different situations that request each one).
Whatever is programmed in the OB100/101 will be executed once, at startup, before OB1 is called cyclically. It is a great place to initialize variables at the beginning of a program, for example.
Hope this helps,
Daniel Chartier
Just to expand on Daniel's comment about the Help files, since if you're that new to Siemens you may not know it. In Simatic Manager (or the editors too), if you highlight a Block (or a command in the editors) and press the F1 key, you'll call up the Help file for that Block or command. While the Siemens documentation can be a bit difficult to work through, the Help files on specific items are pretty good.
181
114
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
111
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
378
