PLC and Iridium satellites
diat150
Mar 2006
Louisiana
1,475
has anyone used any type of PLC to generate the required AT commands to send a "short burst data" message thru an Iridium satellite modem? This would be used in remote locations where there are no other options for communications. Probably a longshot but just wanted to put out some feelers while I look into using this method.
I ran into the same problem, so my company developed a small iridium Modbus transceiver so we could bring in remote rtu's. We can use either serial or tcp. Works great within specifications.
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
89
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
45
29
63
