PLC basics
pravin001
Oct 2005
Pune
Hi
I am a total newcomer to the world of PLC. While studying about the PLC I/O , I came across a statement saying: Modules can be composed of 2,4,8 or 16 points. So I would like to know if points are different from the I/O's of a PLC.
Thanks in advance
Pravin
Thats the problem with these texts, they mean exactly what the author wants them to mean, no more, no less.......
Now out of wonderland and into the real world. Points in this context would be equivelent to individual I/Os. An I/O can be digital, or single bit, or it can be an analog value which can each range from 8 to 16 bits (Or theoretically more). Or it can be a special input such as a counter with 3 or 6 input points translating to a 16, 24 or 32 bit input.
To add to your text, 32 point cards are also common, and 64 point cards are also on the drawing board if not on the shelf.
Points are the number of connections. A microplc may be listed as a 10-point controller which means it will have 6 inputs and 4 outputs (normally). A card (module) could have 4, 8, 10, 12, 16, or 32 points depending...., it still represents the number of possible connections whether input, output, or both.
High Speed Counters usually use the term channel...ie one channel but that one channel may have multiple "points" which are used dependent on the configuration of the module.
Analog cards usually just refer to "channels", the term "points" is not usually used with analog cards.
imho, it depends on manufactures terminology and local customs mainly ...i know comapny, where everything is labeled 'channel' - no matter of type or speed or usage ... etc.
so i guess... author just had in his mind some certain device (modules), one can buy today anything from 1 i/o to n i/o devices ...
I am not sure what local customs would have to do with it. This is 20 or more year old terminology that may be more common to US (or English) products than others but it is used by most in some fashion.
AB, AD and GE regularly use the term "point" when refering to modules etc. Siemens uses the term but not as often, I have seen it used when refering to using a specific common to a specific number of "points". Omron also commonly uses the term "point(s)" in reference to their units.
Omron: http://oeiwcsnts1.omron.com/pdfcatal.nsf/PDFLookupByUniqueID/9F255B35944B008086256A29005C88D7/$File/D11CPM1A0301.pdf?OpenElement
AB: http://www.ab.com/plclogic/micrologix/1000/
AD: http://web2.automationdirect.com/static/manuals/d006userm/d06uservol1.pdf
One I have never used
Mitsubishi: http://www.mind.ne.jp/melsec-f/english/plc_fx/lineup/index_e.htm
Its basically just a reference to the number of connection "points" primarily pertaining to digital inputs and outputs but may also be used for description of other modules. As an example AB in the link describles the starter ML with free software as a 10-point controller. In the OMRON link it shows 30 and 40-point controllers. On the AD website all the digital I/O refer to "points" for the modules...ie 8 point input, 4 point output etc etc.
I wish I had the time to develop an all encompassing glossary or dictionary involving industrial terminology and definitions, including common abbreviations etc.
LOL Steve, took me a few minutes to get the relevance. In other words I may as well try to physically count Avogardo's number.
... just that i'm not from english-speaking country, it's about translation problem in most of companies here :)
Like i said Siemens does not use the term that often. From my German class I can see why that may be...I am not even sure which term you would use in German...der Punkt? die Stelle? die Siete? der Zietpunkt or would it be more technical like der Anschlusspunkt.
Then again you may not know German either and have to deal with a translated version which could have issues.
Steve Bailey said:
Go to Wikipedia and look up "Sisyphus". Also see Alaric's avatar.
All in a days work. o_O
Here is one I created a few years ago, back when I was first learning how to make animated GIFs. I sketched the frames out on autocad, then converted them GIF layers. Its a modern day variant of Sisyphys.
(edit to clarify, I didnt create the avatar (just the home-to-factory gif), The avatar is fairly common on the net)
I have experience programming in an environment where the HMI and the PLC are all in a single software environment. Meaning all the tags and...
3,417
Hi. My background is 35+ years in field instrumentation and I'm doing a college PLC project for a mixing & batch system with pumps, high/low tank...
4,571
Hello there. I just joined the website. We are doing an Automation Technology course. This is the first time my university (UWI Barbados) is...
1,736
Hello all. I have a numeric entry field on a KTP600 basic screen connected to a S71212 plc. When configured for input/output, it shows ### and...
4,658
hi can u plz send me some site where i can learn ,any free online books,i cnt afford money for taking training.i want to learn plc functions plz...
3,444
