unsaint32
I have this water meter that sends pulse signals to a 1769-IQ card (high speed DI card). When I turn on an output to open the water valve, I need to make sure the meter pulse signal changes at least once every second. If the pulse signal status does not change within a second (due to control voltage loss or meter malfunction), I need to shut the water valve. The pulse signal could be either 1 or 0 when the meter stops pulsing. I know I need to use a timer DN bit to trigger an alarm that shuts off the valve. Any suggestions?
