PLC communication
moughal
Jul 2009
islamabad
How to send data from HYPERTERMINAL and receive it on PLc and vice versa????
How the DM memory area is to be set????????
i want send 10 from hyperterminal and receive it on CPM2A output LEDs.......
Hyperterminal sends ascii text via a RS 232 line. I would get a copy of the CPM2A users manual from Omron. Look under the communication section. Look up how to use the RxD (235) instruction. when you set the DM area the first entry on that instruction specifies where to store the dat to the DM you specify. The second value specifies the length of the data. To send via hyperterminal I beleive you will need to use Vt100 ascii.
129
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
153
Hello We have installed several G.E. Fanuc 90 70 PLC Everything was ok but suddenly we can not communicate anymore with any PLC with the software...
81
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
93
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
125
