PLC connecting to oracle
QPex
Mar 2003
Mexico
Hello everybody.. Im new in this PLC thing Im looking for a PLC that can be adapted a barcode scanner, after a readed barcode the PLC should look into an oracle database if its authorized a door will open ... is this possible and what do I need... I really appreciate your help
QPex
If PLC don't need Bar-Code itself, connect reader directly to PC.
PLC-output trigs scanner for reading and scanner send code to RS232C-port of PC when it found or it send 'No Read'.
Use MSComm32.oxc ActiveX control Event property Input len in PC-application.
Use OLE-DB ActiveX controls for Oracle DB-Server connection and
Select-Where some field = BarCode.
Tip! You don't need connections between PLC and PC for that !!!
For door handle use PLC OPC-Server ActiveX write property for permission to open door.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
66
73
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
256
please using the usb can i assign any ip address that i want ?
159
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
98
