plc discrete i/o module
mariasebas
Jul 2002
dekalb
industrial application of the following discrete i/o modules
interrupt input module
voltage comparator input module
latching input module
fast input module
rapid response I/O
relay contact output
wire fault input
Hi Guys, I'm new to controls and PLCs and this might have a trivial answer. I have a small project with a PLC and a inverter. The inverter...
25
3,692
I'd appreciate hearing opinions and experiences of going from discrete controllers to PLC control of temperature. We use a lot of Watlow and...
5,989
I have been assigned a project where I need to use a PID in a PLC5/80E to control the temperature of a chemical in a tank. The chemical goes...
4,754
I need to control a solenoid currently connected to a PLC from an ABB DCS in a remote part of a plant. So the PLC and DCS would "share" control of...
3,377
I'm tring to understand how discrete info is being communicated between two AB PLC 5's on the DataHwy. The data is in an output file (O:31)of the...
8,271
